Good evening gentlemen i been asked to put switched fused spur in the airing cupboard for a shower pump the customer says the plumber says just tag it on to the immersion ! What's everybody's take on this ?
That's my plan just hope there is a socket close enough. I think it's also got those silly straw walls !!
Pretty please?What's it in violation of if it's fused appropriately? Why does it need to be RCD protected?
Thanks!, I'll buy that for the requiring RCD, I thought that something else was being hinted at. Still curious about the why no spur (I've seen loads like it) feeding older mechanical timers in the airing cupboard for example and running the CH pump.Cables buried less than 50mm without mechanical protection?
Sent from my GT-I9100 using Tapatalk
OSG, 8.5; EGBR 4.5 and GN1, C4 advise "Water heaters fitted to storage vessels >15 litres ... should be supplied by their own separate circuit."
[FONT=&]OSG, 8.5[/FONT][FONT=&]; EGBR 4.5 and GN1, C4 advise "Water heaters fitted to storage vessels >15 litres ... should be supplied by their own separate circuit."[/FONT]
It'll just have a pump spurred from it
