P
Piratepete
3 speed Cooker hood motor not running unless I spun it. Changed the capacitor - same value 4microF, same voltage 450VAC, different tolerance - this one +/- 10%, original +/- 5%.
Motor now runs well in slow speed, but doesn't seem to speed up at medium and high speed.
Any ideas - I've never tested one of these 3 speed motors b4?
Cheers
Pete
If the uF value and the discharge voltage of the new capacitor is the same as the old one and it's connected the same then it should be fine. Don't worry about the tolerance.
If this is a forward curved centrifugal fan or a radial bladeset then an increase of 10% in rpm could give you an increase of 20-30% in airflow so you might not notice the increase in rpm between the speed settings.
The actual amount of air a fan moves is usually roughly related to the shaft power required at the motor which in turn is roughly related to the running current of the motor.
Basically the best thing to do is to slap a clamp meter around one of the motor supply wires, if you can see an increase in run current between the speed setting then there will be an increase in air extraction. If you have an anenometer (still can't spell it after 25 years of owning one) then even better just check the airflow directly on all the different settings.
If the discharge voltage of the new capacitor is the same as the old one and it's connected the same then it should be fine.
Just checked more carefully, capacitance is the same. Voltage of new one is 10 volts lower at 440VAC
Pete
Piratepete,
Marvo,
