I
ianphilip007
hello there
after a little advise, just been to look at a possible 3kw oven replacement, as old oven keeps tripping RCD. But there is no dedicated cooker circuit, no cooker switch and no accessable means of isolation for the currently installed oven. The current oven is wired to the downstairs ring main (No Kitchen RFC) and i assume it is spurred via 13 a sfu or plugged into a spurred socket (but cannot be sure as sfu/socket are not even visable let alone accessable.
i have told customer that there should be a dedicated cooker radial circuit and that a suitable isolater switch should be fitted to allow safe isolation in case of fire/emergency. also advised reguards overloading of the downstairs ring main.
Now i feel that my advice and decision to not install new oven to existing circuit is in line with regulations,safe and electrically sound
but i have read that some electricians will connect a single oven <3kw to an existing RFC and dont see the need for a dedicated radial, or becuase its below 3kw local accessaable isolation.
any thoughts please ?
