S
SPARTYKUS
Hello
Does! Anyone know, where, one might aquire the above said item(s) , to qualify and be specific, the round sort found in wall lights, etc, not the plastic box ones for downlighters....
Got a couple of expensive-ish wall lights I'd like to replace this in. Can't source them and wondered if anyone on here knew?
Thank you in advance
do you mean the toroidal ones?
me neither. maybe a remote TX. would serve the purpose.
just looked there. very impressive site. will certainly look at their products for a couple of mood lighting jobs in pipeline.
Thanks chaps, yes good site that topquark, Lennys link shows the sort Im after, just 12V 2.5A 30VA one. About 70mm dia. With approx 30mm central hole. Cheers again!
Thanks Lenny,
I suspect you think I'm a bit lazy not being able to type "Toroidal" in google.
And you'd be right. I am an ashamed man now. :dunce2:
One in the screwed light only has one secondary winding, 2.5A and 12 V. All the ones on line that I can see at 30VA are all presenting two secondaries, 12V but 1.25A each. I'm assuming I can just parallel them.
Edit - some actually say "can be paralleled" in the ad so thats good.
SPARTYKUS,
gutterball,
