I suppose its better than breeding characters with 5 ears, wrinkly furrowed brows, three legs and hairy noses!you've met the ex-wife, then?
It could have been - The last time looked, she had her nose down a pit and bum in the air attempting to fill a termination box with 'jelly'
All types of junction boxes we've used for years no longer comply....unless they sponser this forum.
:) So you're suggesting that if a manufacturer of subterranean terminal boxes sponsored this forum then they would comply?
Having said that, there are some types of boxes with the right type of resin compound filler that can be buried, but most that are in existence cannot with certainty of being compromised.
All outside wiring must be protected by a 30mA RCD
Where equipment is used outside of the main protective bonding zone then a 30mA RCD must be used at some point in the circuit....but that's not what you said :)
I just thought that I would bundle that one in, in case a 5DW got confused :)
Brown is the colour of soil, therefore the brown wire must be "earth" (was actually told this by a householder once) :-)
you mean brown isn't earth???? now i know where i'm going wrong.
Insulation resistance testing of RCD & RCBO’s is good for them. It will put a stop to all that nuisance tripping.
When testing Pyro always set the IR tester to 1000V
IR testing should be done by disconnecting all loads or shorting out all electronic equipment. Particularly useful when doing PIR/EICRs on high bay lighting.....
Never trust an Electrician that needs to blow his own trumpet!! Self praise is generally seen as No praise ...and with good reason!! ...lol!!!
pencilpusher,
pencilpusher,
