I thaught they related to the cable size(although that does correspond to the CCC of the crimp)
I think its red for 1.5mm2
blue for 2.5mm2
yellow for 4mm2?
:confused:
i dont know of any reason why they are the colours they are
red 1.5 blue 2.5 yellow 4 and 6mm
and use a ratchet crimper
There is a standard for crimps, DIN 46237 sorry dont know what the BS is if if there is one. Entering Din 46237 gives loads of info if you really want to look into it.
rent crimp connections and their applications Crimp colour Details Application Red
  • Area, wire size min:0.25mm²
  • Area, wire size max:1.65mm²
  • Current rating:19A
  • Material, contact:Copper
  • Material, insulator:Coloured Vinyl
  • Plating, contact:Electro-tinned
  • Temp, op. max:85°C
  • Temp, op. min:-20°C
  • Voltage rating, AC:415V
1mm² and 1.5mm² T&E
Blue
  • Area, wire size min:1.04mm²
  • Area, wire size max:2.63mm²
  • Current rating:27A
2.5mm² T&E
Yellow
  • Area, wire size min:2.63mm²
  • Area, wire size max:6.64mm²
  • Current rating:48A
4.00mm² and 6.00mm² T&E
Sorry Mucker, trades man like yourself would never use such a thing im sure LOL ;)
PS need another tol for Ferrels too he he
What are crimps for then? and a set of Crimpers??
So twisting and taping isn't up to standard?
