Discuss Crimp colours in the Australia area at ElectriciansForums.net
haj
Good Evening all can someone explain to me the colour system on crimps i believe they refere to amp ratings ?
Thanks for any replies :)
I thaught they related to the cable size(although that does correspond to the CCC of the crimp)
I think its red for 1.5mm2
blue for 2.5mm2
yellow for 4mm2?
:confused:
There is a standard for crimps, DIN 46237 sorry dont know what the BS is if if there is one. Entering Din 46237 gives loads of info if you really want to look into it.
rent crimp connections and their applications Crimp colour Details Application Red
  • Area, wire size min:0.25mm²
  • Area, wire size max:1.65mm²
  • Current rating:19A
  • Material, contact:Copper
  • Material, insulator:Coloured Vinyl
  • Plating, contact:Electro-tinned
  • Temp, op. max:85°C
  • Temp, op. min:-20°C
  • Voltage rating, AC:415V
1mm² and 1.5mm² T&E
Blue
  • Area, wire size min:1.04mm²
  • Area, wire size max:2.63mm²
  • Current rating:27A
2.5mm² T&E
Yellow
  • Area, wire size min:2.63mm²
  • Area, wire size max:6.64mm²
  • Current rating:48A
4.00mm² and 6.00mm² T&E
Sorry Mucker, trades man like yourself would never use such a thing im sure LOL ;)
PS need another tol for Ferrels too he he
Reply to Crimp colours in the Australia area at ElectriciansForums.net
Hi all, Hope this thread is still going. I had to cut my stereo antenna cable, so need to reconnect with another cable. I am unsure as the best...
My FIL wants a cctv system at his house, and normally i would just go with whatever kit was on offer at the time from t'internet. My own system...
Hi, I have always used banjos when earthing the armour on an SWA but have now switched to earthing nuts. I am making off a 10mm fly lead to the...
Lads Can you tell me if there are any requirements for British Trained Electricians working in the Irish Republic ? Specifically, to do...
I've fitted some led lights with power supply and mi light controller, they were working fine and all colours could be seen, then for some reason...
