Are you sure it isn't easier to do what Glenn says and draw a new t&e in using the old cable? No plastering, no soft bendy 4mm going everywhere except where you want it.
If it was dot and dab over existing walls wouldnt your old cable still be in the original containment and easier to work out where the plasterer may of stuck it, ps in hindsight if you know you didnt have a cpc originally before the work started would of been a lot easier back then to rewire the lot properly,
Not as difficult as you think to get it down the wall. You only need to locate the studs (dabs in your case). Then locally create a small channel the in plaster only over these points. Use the voids between plasterboard and wall for the rest. You only then need to patch plaster little bits. For customers, would use quickset plater and you'll not have to come back next day!!
ps: use proper insulating rods to prospect the wall and not coat hangers. This minimises the risk of coming into contact with live wires - how often have you seen taped up bodges behind walls?
