DirtyDog368
HELLO ALL,
i attended a customer with a reported faulty bathroom fan. It was the timer variety with a three pin connection.
I checked the pins and found there to be 240v present so i determined that the fan must be shot. 30mins later i get back with the new fan and connect up but it did not work.
the fan i baught was a ASX100T from greenwood air managment, (a good fan)
there is a three pole isolator switch on the wall outside
and of course the bathroom light switch
at the isolator there are three cables grey, black and brown
now here's the funny thing
when the light switch is closed and the lights are on, the black wire from isolator to the fan is the ony live cable
when the light swtich is open and the lights are off, the brown wire from the isolator to the fan is the only live cable.
from my understanding of the wiring diagram, in order for the ASX100T to work i need a switched live and a constant live.
So am i missing something?
Anyhoo i did try to access cables to rewire accordingly but they are hidden behind a suspended ceiling and access can only be gained by removing this ceiling which is not a real option as of yet.
!- any idea why the circuit is wired up two switch over live from one core to another - could it be a fault or was it supposed to be like that?
2- what options do i have to get the new fan SAFELY working.....
i have included the wiring instructons for the newASX100T fan (1st column 2nd row).....
thanks guys for all your help
DD368
DD368
