A
Anonomoose
I recently got a job in an office of a local business. They wanted downlights taken out and the ring altered. Their regular electrician wanted too much so they used me instead. Job complete client very happy however their regular electrician who still does their work is asking for my certificates. I called elecsa and they said obviously part p is only for domestic properties so no need to do one. Also spoken to other electricians and they say no certificates are needed too. I told the client this and that th regular electricians periodic inspection would cover all the electrical installation but good old regular electrician is still kicking up a stink. Any thoughts people?
You should provide certification for any addition or alteration to an existing installation.
In this instance, unless the addition or alteration involves the provision of a new circuit, or the replacement of a DB, you should provide two MWEICs, one for each circuit worked on.
You could provide an EIC to cover both circuits.
Even for a commercial property though? Do I just issue the certificate and not register it?
Who do you want to register the job with mate? It's commercial, no part p requirement needed. All you do is do the job test it and issue the appropriate certs to the person ordering the work
I didn't want to register it as its not under the part p. just didn't know if I needed certificates or not as other people have said they didn't need to be done. I will bang out a certificate for them this week then. Thanks for your help.
Not with the IET model forms.
The only difference is that a Reg. No. has changed.
Agree with you that the BGB model forms are for a single circuit, but Elecsa MWCs now cover up to three circuits. Was this not part of Amendment 1?
Seeing as how this is not Part P work, should we not be issuing Elecsa certs, but unbranded green ones instead for jobs like this?
Hi mate
you just need to issue a appropriate certificate like a EIC or 2 MEIWCs as spin has stated either IET versions or ones of your own
But not register it as you know it doesnt come under PART P
But all work needs a certificate
apart from minimal like for like change of socket front etc
But if you want to you can even issue one for that
which would make you look more competent and professional to the customer and show the other muppet you know your stuff to
All work has to comply with Bs7671 2011
and a relevent certificate which will include schedule of inspection and testing results and will help show you did all you could to comply and will state exactly what you did do so you dont become responsible for other parts of the installation you have not worked on
retain a copy and send one to client/customer job done customer happy and 1-0 to you
ALL my certs come with the elecsa branding on....!! Dom Com and Ind...!! why you may ask? its because easy cert is set that way and im too lazy to change it!! i have paid there fees for a year so i will get use if there logo every time..!
and yes a MW cert should be issued for the work..! and as stuipulated a cert should be completed in 99.9% of hte time for all aspects of electrical work..! just cause its not Domestic Part P malarki its still accountable to BS7671 of what ever version we on when this thread is read many times over!!
Bit worrying that you didn't know the requirements to issue a cert(s) mate? Day 1 sparky training nest pas?
As for the other spark' he's clearly ****ed that he didn't get the work. He has no entitlement to a copy of your certificate unless he is an employee of the client, and then he has reasonable justification to see a copy of it. If he's a self employed sparky I'd tell him to put his toys back in the pram and do one!
If you are Elecsa Registered then no problem. You need to complete one of their 'Electrical Installation Certificates'. They don't say 'Domestic' on them, so it is fine to use it. Since this work is not covered by Part P, then don't need submit to Elecsa as you would have done for a Domestic job.
Registered Elecsa Sparks can download free blank copies of this certificates off their website - only problem is they are not in colour!!!
