R
robjcox
Hi all.
My electrician is issuing me with certificates without a signature. The certs are completed via a computer then posted to me. In the signature fields are the names of the installer and QS printed but no signature as such, not evan a scanned one.
Is this acceptable?
Regulation 631.5 states that any certificate can be issued durable medium either written or electronic.
They must though be original and have their authenticity and integrity verified by a reliable process or method.
To be Honest I would have thought if it had the name of the company and it's representative on it, then they are authenticated as such.
Have you asked them a) why they don't actually sign them b)If you sent them or took them to their office and supplied a stamped address envelope, will they sign them for you
They should be signed. You will either have been issued with a single signature certificate, where the electrician has done all of Design, Construction, and Testing and Inspection. He should have signed in one box to cover all 3. Alternatively, he may have issued you a cert requiring up to 3 signatures, if different people within the organisation who did the work for you only carried out a certain part of it. In both cases the Electrical Installation Certificate, should be accompanied by a Schedule of Test Results, and a Schedule of Inspections. Without both of these the certificate is not worth the paper it is written on. Have you contacted the company? It may just be an innocent oversight on their part.
Cheers...........Howard
Without a signature, the Certificate is not worth the paper it's printed on.
Get in touch with the electrician, and tell them to sort it out.
So what your saying guys is that only a signature is classed as a reliable process or method.
A company stamp and the names of the representatives do not count ........fair enough I stand corrected
Having seen my fair share of dodgy and obviously fake certificates over the years
I wouldn't accept a certificate with a scanned signature or no signature as alarm bells start to ring that they may be fake and do the people whose names or scanned signatures appear on them know they are being represented in this way and accept that the information on them is correct and the liability that goes with it
I have no doubt these cetificates are genuine. The company involved have recently switched to electronic certification which means the actual installation engineer may not be able to sign it between the data being entered onto a computer and the cert being issued.
My question is really whether or not it is a requirement to have an actual signature?? I have had experience of scanned signatures being used with EasyCert for example but these are coming back with just the name printed.
I use NAPIT Desktop and this prints my name in italics with "electronically created" underneath in the signature box.
The authenticity is ensured by the process and the ability to check authenticity with, in this case, NAPIT.
Have you seen the new style MOT Test certificates? No need for anything fancy these days as they can be checked against the central database
Simon.
So there are other means of reliable process or method, in authenticating a certificate other than a signature.
Guys this is the 21st Century, and we are always quick in denouncing the IET for being slow with things, but if they felt that the only way a certificate could be authenticated was by signature only, then they would have put that in reg 631.5.
In today's electronic world sometimes documents can not be signed and there are other ways do do it, hence why the regs comment on reliable process or method, such as Simon and I suggested.
First there was the wax seal, then the signature and now .........................computers.
You are now introducing a level of error which is possibly not being checked as the person entering the data may inaccurately enter it
Without a signature what legal status does the certificate have ? if something happens would it have any standing in court if it was not signed
I think I would want any testing and certificates attributed to me checked and signed off by me and not somebody just slapping my name on it as I would be the one standing in court if something happened
While computer generated certs look much neater a lot of the uniqueness of a hand written cert is lost
As far as I'm aware, the OP has received some pieces of paper, not electronic/digital media.
This to my mind would be the same as handing someone an unsigned cheque.
You can make payments to someone electronically without physically signing anything, but there is always some method of verification involved such as a PIN number.
If the cetrificate had been Emailed to the client, and electronically signed, or had a scanned image of a signature pasted into the document, then fine.
However from the information provided, that doesn't appear to be the case.
It appears that the Certificate has been produced on the computer, printed then posted to the customer.
I would imagine if it is on a certificate that is issued as part of a scheme such a NAPIT as Simon posted, or if commercial/industrial environment on certification that carries some form of company logo or covering letter, and that is emailed then it would easily stand up in a court of law.
My home and contents insurance is with a company called E-sure and everything was done over the internet, original application via website, then documents to us via email, and with no signature on any paper work.
I doubt very much if I had claimed and E-sure came back and said that because none of their documents had a signature attached, therefore they are void, I would not have had too many problems winning a court case.
From reading the Part P Regs the person entering the data onto the certificate must be the person who installed, tested the installation.
Even on the new MOT certs a signature is still required and the person who did the test had to fill in the data.
At the end of the day if someone is getting a 'young office girl' to do the certificates then whats saying she is fussed if she enters the data in wrong or not!
1.9 of the Part P regs
The electrical installation certificate must be made out and signed only by someone "qualified" to do so.
An office person is not "qualified" to do so! Even if another Electrician is filling in the certificate why didn't they do the work in the first place if they have the time to sit in the office doing certificates!
Send it back and at least get a signature.
Might also be worth mentioning it to their assessing body - this is not acceptable!
When they did the work and tests did they fill in a paper certificate at yours or did they just use a scrap bit of paper or back of a cigarette packet
Bad choice for an example IMO as your online form filling will have a electronic journal entries on their system and will be fully traceable. May be there is a business opportunity to have an online traceable certification system like the MOT system is it possible something like that would reduce the number of cowboys out there
