M
MAD MAINTENANCE
Hi all,
I want to install a Ariston Europrisma undersink water heater 3kw - 15lt. The testing and certification will be done by someone else. This is a great opportunity for me to gain some much needed experience as I am only a little way through my course and I have only helped out on a few other installations. I will have comfort in knowing that someone is going to check it over so this is good.
I have worked out that I need a mains supply with 13 amp together with a Heat resisting 3 core cable of 1.5 mm,
There is a fused spur unit in the room,
Can I change the FCU from a flush to a mounted unit then run my cable from that to a 13 amp double pole fused isolating switch then from there to the heater?
What trunking shall I use? ( It will be on show )
Sorry for the amateur talk guys, :wink5:
Cheers,
Dan,
Mad Maintenance.
Cheers,
Dan,
Mad Maintenance.
