T
timo1
Hello All,
After a little bit of advice concerning a partial rewire / renovation of a flat. I haven't done much work in this type of property apart from a bit of fault finding on a couple of occasions. This is a big job for me and a good opportunity for me to make some decent money at last!!
The flat is in a lovely Art deco building and the flat is a moderate sized two bedroom property. The existing wiring is twin and earth PVC in metal conduit, the C/U is a really nice looking but very old MEM metal clad unit. I will be installing new circuits for kitchen sockets (20a radial) lighting in several of the rooms (customer just wants existing lamps re-positioned.) feed for a macerator and a boiler.
I'm not sure when the wiring was installed but the C/U seems older than the wiring which I thought may be 1970's? Anyway my question is would any of you encourage me to keep the existing wiring, provided it all tests out ok? The property will be open and unoccupied but obviously it will mean a full rewire and if I don't have to do this then costs will be lower. If I keep the existing wiring circuits then it will be half of the properties lighting and sockets, the rest will be new wiring (PVC twin and earth)
I intend to upgrade the C/U with ideally a plastic unit all circuits protected by RCBO'S and a smaller similar unit for the storage heaters. I consider my options to be, if I keep the existing wiring, to to use the old CU as a connection box (for want of a better word) and extend to the new CU (tails will be new obviously), or remove the CU and ensure the earth continuity is maintained by fly leads to the new unit?
As I'm reading this back, I am just thinking why not just rewire it all at once, I just don't want to throw baby out with the bathwater, and in future if I am asked to replace a similar CU in flats then I probably will not have the option of a rewire. Here is a photo of the unit and current set-up. I appreciate your time in looking at my post and would be very grateful for any advice from anybody that has experienced a similar scenario. I would love to remove the old CU as I want to use it as a spice rack :)
if the old wiring is stranded cable and passes tests, don't replace it, it's better cable than the solid crap we're stuck with now.
Thanks Telectrix, that was kind of my thinking, the installation has obviously been done with some care and I would be happy to keep it. What do you think is the best way to extend the circuits to the new CU?
You may find that you can rewire through the existing conduits,especially the lighting if the system is full conduit,you could use singles
The existing socket cables,check on their cpc size
If its partially rewired,you can fit the new cons unit with the new circuits nearby and use the old board as a joint box,strip out the guts and perhaps a din rail mounted in there to extend the circuits or just crimped connections and plate it off
