i can see it now,terrorist charged with not being part p..now theres a film id pay to see..i can see brad pitt as a niceic inspector,
He would have to be renamed Earth Pitt
There would be R-Cid featuring the life of Ben earth
Close encounters of the 3rd kind could keep its title and star Kathrine Heapburn
Then there is
jurassic park when the kids climbing the leccy fence and the power turns on on its own whilst hes mid climb and he gets belted when hes not in contact to earth??
There was a movie where there was 3-4 bombs on a cruise ship so they have 2 colours to pick from red or blue and they have a gun to the bomb makers head and he says cut the red wire to make it safe the top guy says Ill go first then says well here goes so he puts the snips in and changes his mind cutting the blue wire he then shouts to the rest of the team cut the blue wire so whats the big deal .
Well he should have told everyone what he was doing because if when he cut the blue and the bomb had gonr off then everbody else would have thought he had cut the red so they would have cut the blue.
Thats the worst about being technically minded in the movies you see the lift drop twenty floors but they have gravity brakes fitted and they kick in after it drops past 1 or 2 floors then there is the wires where you see one snap and the lift starts to drop yet there are 4 ropes fitted and each rope can take 120% of the actual lift load
All very true, but they also forget the ket point about lifts,
IF all of the brakes and fail safes (eg gravity brakes) are removed from the car and it is allowed to move freely in the shaft (ie the stereotypical brake fail) then the car would go up, not down as the counter weight is heavier than the car + passengers hence why is its so important not to overload lift cars.
sounds like you know what your on about .... care to elaborate .....
Yes, I had a few years doing Auto electrics when car theft was at it's peak. We recovered dozens of stolen cars with ignition and lock damage. If you where to try and start a car with the wires the way they show you on the films you would have no chance of staring it; EG for a start the fuel pump and ignition circuits would not be energized.
On a modern car it is almost impossible to start the engine without the key, even if you get to the harness behind the ignition switch.the key is coded to the ECU. I say almost because I bet someone can do it.
One of the soaps a few weeks ago showing a fire alarm breakglass with the indicator flag showing it had been triggered but the whole assembly upside down
I recently saw a TV program that some "so called" electrician had to drape a orange lawn mower flex access a ceiling because the interior designer thought it looked good
Oh......
Wait.......
That was me and CBW's lad Shaun...... DOH!
Oh......
Wait.......
You can't talk about Billy like that
