E
EasyMCSLtd
Re: 2 Weeks of MCS Accreditation Talk - Gaining MCS & Maintaining MCS - Expires March
Sarah
I'm here more for the paperwork side than the technical, but you are required to complete a PV Array Test report along with a PV Installation Checklist. You can find the layout for these in the DTI Guide to PV in Buildings, which is the "bible" for the technical side. both these documents would be given to the customer in the Handover Pack and a copy kept for the Contract File.
When the panels are installed, what actually needs to be tested on the roof please? I know that there are positive and negative DC connections, but will just checking the voltage of each panel (prior to mounting them on the roof) suffice, or do other things need to be checked? Thanks very much in advance.
Sarah
