M
the Outgoing live terminal of the main switch is feeding all the breakers directly via the buzz bars .
the rcd is being fed from its top and bottom terminals as its conected to the already live buzz bar and also being fed by the flylead from main switch to the top.
however if you follow the current path of the second ring main the neutrals are connected to the right neautral bar so its only route out is via the N of the RCD! hence the rcd trip fault .
if that makes sense???
