Did i miss something ? I thought this was to control one set of lights not a circuit of lights.
It's a 2 way light with neutral at the switch, the switched live comes from the second switch (permanent feed to the first) then the OP wants to take a feed from the second switch to control an additional cct.
... Unless I've got lost somewhere.
I'm assuming that as you are extending a circuit (in some way), you will be testing it and filling out a minor works certificate?
I'm also assuming that you are qualified in some way, therefore a "competent person" and you just want help clearing up a circuit design you haven't used for a while?
If not, then please get a qualified electrician, as I am tired of getting called to DIY jobs which are left in a potentially lethal condition. It is easy to see why we ended up getting stuck with the part P fiasco....
