i have a very vague idea what part p is. i was going to join the NICEIC as you have to be with them to get any council work where i live.
yes i have got a copy of the BS7671 red copy still need amendment 1 as for the city & guilds 2382 yea i sat that i done the 1 day update from 16th to 17th edition
what it is....theres these legalised conmen ..otherwise known as the gang of three....the part p scheme providers.....theres the NIC....and NAPIT....the other criminal is ELECSA.....if you join one of these `schemes` then you dont have to go throug the LABC....another set of parasites......can you see where this is all leading to....oh, by the way....what you will find is that a lot of work isn`t notifyable anyway (minor works outside special locations)....stuff like that.....
so, you've got 2382, 2 jobs ( 1 major, 1 minor) for assessment, PL insurance, calibrated test gear, various other bits of documentation, confidence and competence, contact niceic to book your assessment.
yea i know that obviously i will need to do my 2391 at some point. but while i dont have that how will i be able to get my work tested. and do you think that joining the NICEIC would be worth while
if you join the NICEIC do you still need to do part p. or does the niceic cover this
Whether or not you are a member of a self cert scheme provider or not, then yes you have to comply with Part P. Part P of the building regulations is a legal document, and must be fully complied with or else big fines and a nice break in one of her majesties hotels will be forthcoming if you cock it up.
Cheers................Howard
are you competent at inspecting and testing.....if so then whats the 2391 got to do with it??
to be honest, at this moment in time, don't waste your hard earned. to be accepted by one of the parasitic scam ( and niceic is the worst, so i've been told) you have to show that you are competent to test your work. for the present, stick to small non-notifiable jobs.
could you not legally test your work if you have part p and 2382 inspection and testing?
i havent even looked into pl insurance yet i know test gear is expensive specially as i would prefer to have megger stuff. i will sit 2391. still need van some power tools not much tho as i have quite a bit already but i guess i could build that up as i go along
ABerry82,
Silly Sausage,
