A
ABerry82
hi just wondering how long should you allow to change a fuse board and how much to charge the customer ? because i dont want to be too cheap but competitive
How long is a piece of string, comes to mind with the information you have provided. Unless your doing multiples of CU changes on say, the same estate you can quote a pretty standard rate, but generally each CU change is going to be different, and each CU change would need cost assessing in it's own right!! How often you could apply a standard rate to a CU, is hit or miss i would think....
lets say that the CU in question is just a 16th edition 10way split and your updating to a 17th edition. The incoming wires are just the old red and blacks and all they have asked is for the board to be changed
And the bonding needs doing??
The reason i am asking is because i get alot of people asking me to just change there board my old boss used to just say £250 but i have seen alot of people on here quoting silly prices so i was just wondering what other people are charging
Have yet to come across a customer that's wanted a 16th edition board upgraded. Has this been recommended to them by a spark or is there another reason for the upgrade?
If it's a straight swap and all tests out fine, no bonding, no tails, no alterations, no fault finding and correction, then I would say £250 would be about right. Any of the above list would be extra. You'll get plenty of work at that price and still make a good amount of money.
Our average price for a 4-6 way rewireable board swap (inc meter tails pack and test and part p) is £250. We are in Leeds
