skiped through the thread,, laughted at some posts,, but seriously, hope his ok... was there any indication of a cable being in that position??? if not then I think the DNO should put their hands in their pockets..
(again as i said skiped through so might have missed somthing)
Yes you skipped too much he was trying to dig around dno cable so he could get it closer to wall .... all blame on the labourer
dam beer...:) I really need to stop drinking
stupid plumb,, hope his ok though
I think you need to look at the pictures!
The cable is on bloody visible, a partially sighted man could see it.
Where is this conservatory? The front of the house? Don't all incomes come into the front?
exploding hand tools.....seen that before.....its surprising how quick a solid lump of metal will turn to smoke with even household voltage supplies....the supply was supposed to be cut off? I don't like when cables get rolled out and then concrete or cement screed put over them, that could get removed with a chisel or a breaker drill one day and split.
I don't like cables put in like that poking out of the floor...
did one for a gardener who had cut through the incomer. it came across the front lawn and was only 6 inches deep under the turf
Dave 85,
JD6400,
