G
GLENNSPARK
that is to say the closest point to the incoming service (water) that a BS 951 clamp can be applied......
Dont you believe it Des!!....seen this scenareo quite a bit....where someone has seen fit to apply bonding to one....then not the other??!!Properly has bonding to gas but not to water (evident by only one bonding conductor into the CU).
Perhaps its already done,it makes little sense that someone who is aware of req for gas bond, then omits the water
I would disconnect the gas bond at both ends and continuity test between an end and the water pipes in case its a continuous bond for both
