P
potatoman
Hi ,how do you check the resistance of a cable thats about 140m long, goes through 3 consumer units and between the consumer units it is different sizes
measure each section and addd up.
more to the point, why need to know?
How about answering the question
thought i did in post#2. measure the resistance of each section, the add them up. low ohm meter, then a pencil and paper ( or , if you are flush, a calculator.)
Use a low resistance ohmmeter and a zeroed (very) long lead to measure the resistance of each section and add the resistances together.
If you have more than one of the same size conductor connect the conductors together at one end and measure the resistance between the two conductors at the other end and halve the result to get the resistance of one conductor.
