L
Litttle Shonet
Just changed an FCU, and terminals are in different places, therefore a bit tight for some wires.
Just wondering what length of cable you all leave in back boxes for such eventuallities!
Cheers
i leave as much as i can and still get the faceplate on. ( within reason )
now i know this is a replacement...but when installing new i always go for a deeper knockout box (if and whare i can) for FCUs.....as we all know what a pain in`t arse they can be.....
If you measure off conductors to the corner of the box and add an inch generally its spoton
I have a friend who does hairdressing at her home.
She had some double socket-outlets installed in her room she uses as a Salon.
One of the socket-outlets was upside down, because the conductors were too short.
A through crimp and a couple of inches of conductor and it was sorted.
when cutting cable/s to length i grab em with my fist...cut em to leave a fists length....that sorts em....
leave one of the CPCs long......then snip a length of G/Y sleeving to go to the pole on the knockout box.....double the CPC over...so its continuous and terminate into the knockout box.....re-sleeve.....then into the back of the socket/FCU with it.......
Litttle Shonet,
londonlec,
