T
thekingiam
does building regs alow us to knock out the occasional brick?
just wondering i have in the past done it as when necessary.
I can't recall a time when I've had to do it but common sense would say that because the building regs allow us to drill a hole in a joist they would allow a hole in a wall as long as the structural integrity was not compromised
Can you imagine a scenario when knocking a brick out would cause a house to fall down FFS!
got a rewire and sockets in conservatory being fed from under floorboards in bedroom.
they have all been put in the old cavity in the wall they have been cemented.
i have often removed bricks from under doorways or where no load, and ime sure removing one or two bricks as long as replaced after is fine.
Unless you're really unlucky (and the wall collapses), the worst that happens, if you take a few out in a row, is that higher bricks fall out in a triangle, apex at the top.
it's 2 bricks about 2 metres apart it will be fine.
just wondering if any regs about it?
Haha...probably, there's a reg for everything else, 90% of which can be ignored by the appliance of a bit of common sense.
Men get paid large amounts of money generating most of this nonsense.
I vaguely remember watching some documentary on some particular engineering crisis, and some boffins in a lab concluded that so long as the wall was built correctly to start with, you could remove nearly 50% of the alternate bricks before the thing would lose it's strength and collapse. Not sure I'd like to put it to the test!!!
