hourses for courses. On some jobs, with decent bare galv glandplates, then IMO banjos are not neccesary, but there is nothing wrong in fitting them. If this method is used, then i always bolt a flying lead to the glandplate, to ensure it is earthed reliably.
On many of the jobs i carry out, then the banjo is bent and installed outside of the enclosure, and they are all linked and bonded to the nearest steelwork or unistrut ect. If the armour is also used as CPC, which it often is for instruments, then we use another banjo inside the encloure too.
There are many ways of echeiviong the same result, and often its down to personal choice, cupled with the environment your working in.
hourses for courses. On some jobs, with decent bare galv gland-plates, then IMO banjos are not neccesary, but there is nothing wrong in fitting them. If this method is used, then i always bolt a flying lead to the glandplate, to ensure it is earthed reliably.
I think your right John, it seems from here its a personal choice, he was using the armour as the CPC so I would have just preferred to see it drilled in the gland plate, and then linked, I would normally fit multiples as Tony showed above.
Ahh well see 20 years experience and still learning :)
I have had a related problem recently. I got a slating for drilling the banjo of an swa to the underside of a stainless steel enclosure / control panel as I was informed it ruined the enclosures ip rating. I had used a 6mm brass nut and flat brass washers. Surely the 20mm hole for the gland would have needed an ip rated washer and better to use gorilla nuts if this was a prob. The enclosure was outside but underneath a huge canopy in a loading dock. Was I wrong or unduly slated. Appreciate any advice.
To be honest think we need to see how you drilled it, and what kind of environment it is in, though you did say outside, what is this outside in, near the coast or in an explosive area??
Did you drill the hole with the correct size bit? If you used an over sized bit then the bolt may have been flapping about live a privy door when the navy is in, and yes I would have slated you
If though you had use the right bit and it was an environment issue that as your the apprentice the sparks should have either given you some sort of fibre sealing washer to use, or an earth nut, so he is the one that should be slated.
Thanks for the reply. I used a 6mm cobalt drill and the panel was in an area with no gasses, explosive flour dust or chemicals.It was installed in free air with no more to expect than a light dusting from rain blown in from the wind.
Are you saying that you haven't seen a banjo arm bent up within an enclosure to receive a nut/bolt and fly lead in 20 years on the job?? It has to be more common to see, than drilling through the enclosure. Personally i'm not too keen on banjo's these day's much prefer the Piranha earthing nuts... lol!!
Just spent over a month bending banjos at a national grid gas terminal in Scotland. There Is no exception on this particular site as it's atex / compex site. This little job however I drilled the banjo for aesthetic reasons as the other panels and sw.fuse in the same area had been done in the same way. Just wondered if a correct sized hole with corresponding nut and bolt (separate cpc ) would really compromise the ip to such a degree. I agree there are other methods but is this a definite no no these days as I haven't had a problem in the past.
These are good if you worried about snapping your banjo.
