Make an appointment and you can come and watch.
:smug: Ok, seriously now, how do you get through a pressed concrete post biff55 without hammer action?
Most "hammer" action drills I have seen and used over 30 years don't even start to make an impression. The only way I have managed to drill into a pressed concrete steel reinforced post is using an SDS drill. with the hammer action most definately on.
Without it you will just sit there watching the bit get hot ?
Just confused? Do you have a secret method?
Just wondering if you are on the wind up ... ?
S.
You only have to drill in the first half inch without hammeraction before switching it on to prevent cracking on the surface.
And modern fence post concrete isnt particually dense , rather powdery i find.
And if your just plugging for a cable cleat , then youre only drilling 30mm deep with a 5.5mm bit , quality sds bit should cope.
Dont see what all the fuss is about to be honest.
And i find it best not to take forum debates too seriously
no fuss, it's a forum!
I'm glad you don't take them seriously.
Thanks for your reply.
If I couldn't bury it, I'd be inclined to run the SWA inside some polythene cable duct to protect the sheath from garden tools. (Like the blue underground water pipe, but black.)
I'd agree. Its very useful if penetrating deep into a flowerbed. But difficult to maneuver around a path.
....and as for drilling preformed reinforced concrete posts with a non-impact drill - lol
Yes, it's not very flexible. If you have to have tight bends, then the twin wall corrugated stuff might do the job, but the minimum size commonly available round here is 63mm OD I think, so quite bulky.
We've used the corrugated pipe as well with some success. The Polyethylene water pipe is the best. You can hit that stuff all day with a pick axe and the SWA inside is still unaffected.
The main point here though is: If the job is done properly then you would normally do a risk assessment and calculate the likelihood of damage and take precautions. In some cases, quite expensive, plants and undergrowth withstanding. Ideally, conduits are laid in trenches with inspection hatches while the planning and earthworks are being established with termination boxes placed in the hatches and further pipework to the point of utilization. Anything less in the planning stages is just DIY. - lol
you been smoking them funny smokes again, rodney?
Mastering every electric powered opinions you could be able to assistance in producing ones back garden to take a look much more wonderful and protection./
I liking assistance for garden in with gates. Electric wires possibly due to stoats. Daz
Think of a more positive message for this customer who is concerned about his bedding plants!
After April 6th he'll be able to do it himself anyway. Then I'm sure it will be a safe and compliant installation :):):)
