G
Greg:
its raining and an RCD is tripping. Patio has been laid around the outside of the house and a galv terminal box into which the three core SWA is attached is hanging off the houses outside wall. The E (of the T&E) leading from the house has been severed somehow within about 10mm of the wall surface and the L & N (of the T&E) are both showing copper at about the same distance from the wall and the insulation all around is fairly charred. The sheathing (of the T&E) is stripped back to the level of the wall surface).
So I open up the masonry at the point the T&E makes its exit and found that cable runs down from the ceiling which doesn't help. The SWA runs down.
I'm now thinking of crimping on a short extension to the T&E leaving the join within the wall cavity but am wondering about the connector. I've tended to connect adaptable boxes to the snug interiors of buildings. I was hoping that someone could talk me through the use of external terminal/connector boxes for three core SWA as a point of connection to a T&E feed.
