G
Giannis86
First of all i would like to say hello to everyone,
I recently got a Grasslin Talento 472 Timer and after a lot of struggle and reading the manual i managed to program it properly as my needs required.
The problem:
Due to my lack of knowledge in wiring i cannot understand how to wire this thing.
Click here for the manual
As you can see from the diagrams, there are two channels. I would like to connect two lighting bulbs to the unit (each bulb to a separate channel)
Attached you will find a picture of one side of the timer (channel two is on the opposite side)
The wires were like this when i got the timer (connected to one lighting bulb). I am not sure if it was done efficiently but the bulb did work.
Could someone please help me figure this out? Maybe by means of a simple picture :o
Thank you
after some reading i came up with this wiring scheme
Could someone tell me if i did it properly?
Thank you
Thank you
Looks like it should work to me. personally I normally use terminal no1 as live and no2 as neutral, although it should work either way if you're on AC.
Obviously you need to make sure the voltage of your lamps is the same as the timer, and that the current rating of the switch contacts is suitable for the lamps you're using and the protective device backing them.
Giannis86,
johnstantine,
