F
foundryeng
I have wired a Meniver SD2autodialer into an alarm system and all appears to be good until the unit goesto dial out. I have run test facility and the unit opens the line and thendials. I can hear a dial tone before the dialling but the call does notconnect. Then before you can hear any connection to the dialled number the unitstarts to send out the recorded message after a few seconds. The line test onthe unit shows that the line is ok and the fact that a dial tone can be heardbefore it dials the number would suggest that the connections here are OK. Canyanyone suggest what else may be wrong with the unit or the setup.
I would really appreciateyour help in this as it is very frustrating that it will not work.
Make sure there are no messages on their 1571 (or equivalent) answering service. I had one where they had messages that they had not listened to and it blocked the dialler making calls. If that is it, then your customer needs to have it removed from their line.
Have you tried a fliter on the line? I had a similar problem were it would dial then just cut out.
Thanks for reply. I don't think I need one as the line is on BT infinity and the master socket has a filter built in. I will try it though as I can't see anything else that could be wrong at the moment. If anyone's got any other ideas to try I'd apprecaite it.
Just double check the line on their handset for a broken dial tone. If its not that, then try the filter as suggested.
foundryeng,
KevinS,
