F
foundryeng
I have wired a Meniver SD2autodialer into an alarm system and all appears to be good until the unit goesto dial out. I have run test facility and the unit opens the line and thendials. I can hear a dial tone before the dialling but the call does notconnect. Then before you can hear any connection to the dialled number the unitstarts to send out the recorded message after a few seconds. The line test onthe unit shows that the line is ok and the fact that a dial tone can be heardbefore it dials the number would suggest that the connections here are OK. Canyanyone suggest what else may be wrong with the unit or the setup.
I would really appreciateyour help in this as it is very frustrating that it will not work.
