G
Guest55
It may look untidy, but a wago is always a superior connection on solid core, to a crimp imo....![]()
now we have the pleasantries out the way , ;-)
agree with eng54 , wagos in CU look like amateur hour.
Because they will look like a bloody armature has been at work. Nothing wrong with Wago's, they just don't sit well being used in a CU!!!
The last time I saw an armature is was inside a motor , armatures and wago's dont look the same!
Unfortunately there's no way to 'like' someones signature on this board but I did try Biff
I'm probably just oldschool but I much prefer crimped ferrules. Great mechanical strength (assuming you use a good crimper) and a very low profile and neat form factor when used with heatshrink; the joints are almost invisible when they're in a wiring run. I've used Wagos (once or twice) but you hardly ever see them in this country. They're convenient but they're helluva bulky especially if there's a few of them in the same area, I can't really comment on their reliability because I haven't sufficient experience with them.
No, ...Never use PVC tape on crimp connections always use heat shrink!!! For an even neater job you could use bare crimps with 2 layers of heat shrink to insulate them. Or you can buy heat shrinkable insulated crimps. For aesthetics sake, i always like to see the appropriate core coloured heat shrink over crimp connections...
Read this and thought, yeah, that sounds like the dogs doo daas; I've got a heat gun, I'll do that. But then I thought. Hang on, I've got no power during the CU change, how can I use the heat gun? There's a hole in my bucket dear lisa.....What can you use as a source of heat when heat shrinking over crimped cables during a CU changeI'm not that much of a lover of those bulky PVC insulated crimps to be honest. I much prefer the uninsulated crimps (using indent crimp tool, with a couple of layers of heat shrink insulation, or the heat shrink insulated crimps with a correctly coloured heat shrink over cover . Remember all heat shrink tubing coloured, or otherwise are of XLPE construction....
Made me chuckle thst malcolm
