a bit off topic but brass bushes and cheap k/o boxes have little fragments of metal too, they get into your finger tips and cause them to turn septic
its magnifying glass and tweezers time to remove the bug---s
I got a splinter of these fibreglass rods under my fingernail once but prized it out,use gloves and no probs,even if they are £5 they are still worth it.
I got a sliver of fibreglass in a finger once,finished up opening half my finger with my stanley to get it out. Bloody hate hospitals so went for the diy approach,luckily it ended well.
I use a snake (Fish) otherwise known as a draw tape, failing that I use the more flexible red plastic conduit as used in circulating fire alarm systems or occasionally a bit of flat plastic trunking lid....I have never used fibreglass Rods and never intend to, I wouldn't even trust the fancy looking £200 kits.........not for me......use a nylon draw tape...
I use super rod and I've only ever had problems when I tried to bend one of them at >90deg up a pipe in a every confined space. That completely knackered it and nearly caught some splinters in the process. Otherwise I found them perfect for fishing around across inaccessible spaces, particularly when using a magnet.
I really can't see a problem with these rods as long as you are careful and don't overbend them.
I've never had a problem. Like mentioned, I don't over bend them. Never noticed instructions. I guess it's just one of those things. I've broken a few of the cheap brands though. Don't buy them. Tip on the rods, when they're stuck, spin em
i've used all of the above over the years, plus old fishing rods!
re splinters - if you get one that's hard to remove, mix sugar and soap together, smear it all over the affected area, cover and sleep with it like that. in the morning your splinter will be hanging out of the hole in went into!
honest, it works a treat!
trying to do electrical work with gloves on is a real bumm-r!
yeah your right, some builders I know insist that operatives regardless of trade wear gloves at all times, I have told them myself to try to connect up a socket outlet with a pair of gloves on, lol bloody builders.
As a result of this I've bought myself some Hellerman Tyton rods (they were on special). They seem much better quality, only thing is, the connectors are a lot bulkier.
I have also bought (on your advice lads) a super fisher.
cheers all
