I think they polled the customers and discovered a hundred percent want fashion over function. And if it looks pretty customers (women) are prepared to pay any amount for it!
I had the misfortune of trying to install 20+ wooden light fittings which had crappy terminal blocks and about 2 square centimeters of space to work in. The terminal blocks filled the space inside the fitting so no space for cable, also no cable entry point. Absolute rubbish. I had to replace all the massive terminal blocks with smaller 6amp ones and wire the whole lot in flex. Nightmare.
Nearly blew my top yesterday...... nice easy little job for a monday (morning), fit x 15 down lights, holes cut already by customer, loft above - simples.
BUT customer to supply lights, didnt think much of it as have supplied my own downlights for so long now and forgot how cr@p other stuff can be.
A job which should have taken a few hours tops ended up taken nearly double that (and I'd done this on a price.)
Basically matey had brought them off ebay!!
I went to fit/push up through the hole and the spring wings were so tight that if I pushed anymore the plasterboard would have cracked or wings would have bent.
Ended up having to take all wings off and fit from above, absolute nightmare trying to re-fit .... fighting against each spring, having to stop light from falling out below and laying in a superman position!! :cuss:
Never again.
When customers are insistant that they supply the parts I state that ANY time spent sporting out any issues will be charged at my hourly rate - that normally makes them think again!
Never again.
When customers insist on suppling parts I haven't agreed to, I state on my estimate that any issues with the customer supplied parts/work will be charged at my hourly rate - it normally makes them think twice!
Thanks Murdoch... good idea there think I will be adding that little number to my T&C's :yes:
As a direct result of all the above, and one particular client that bought a load of lights in france, i added the following to my T&C's about a year ago....
Equipment and accessories suppliedby the client. CSES Ltd reserves the right to refuse to fitsub-standard, non-compliant accessories or equipment supplied by the client.Quotes and estimates tendered by the companyare based on the fitting of standard electrical accessories. Accessories that require excessivepreparation, modification or non standard fitment may incur extra cost to theclient.
