S
Sbc
Hello all,
A quick question... when selecting a protective device should you use the nominal voltage or the measured voltage?
example
9.8k / Uo = 42.6A select 50A mcb
9.8 / measured voltage 245V = 40A select 40A mcb
Thanks in advance
I'm assuming that what you're talking about is protecting a shower. In which case, the 9.8kW will be specified at a particular supply voltage. If you increase the supply voltage you will INCREASE the current and the power, so you calculation is incorrect. What's fixed is the heater resistance (or nearly so), not the power.
Generally best just to use the nominal figures.
For you,re 9.8KW @ 230V the resistance would be 5.4Ώ
So for you're 245V supply it works out at 45.5A assuming a linier coefficient of resistance/temperature. Which you can't.
Handysparks, Yes its a shower. 10mm cable. Manufacturers instruction say 45A breaker except cant get wylex 45A that easily. Shall i go with 50A breaker then?
Tony, what is "linier coefficient of resistance/temperature" can you explain further please?
Unless things have drastically changed in design, you are suppose to design everything at Uo
Most showers though are rated still at 240v which does make our life a little complicated but if you design to 230v then you are erring on the side of caution by saying that your load is going to be higher.
You never though design to RMS .....................
I would stick it on a 50a
No idea and I don't even know what Linear coefficient of resistance/temperature is either, don't think it's relevant
Linear coefficient is really to do with thermal expansion and no on a domestic shower circuit I don't think there is a lot to worry about ..............Think our Tony was slightly pulling the leg
If you're using 10mm² T&E then, providing your correction factors don't drag the current carrying capacity down too far, a 50A breaker will be fine.
I think Tony meant to say that, if the resistance of the heater remains constant with current/power, then the current will be... This is probably reasonable, as the element is surrounded by water, so it's temperature, and therefore resistance, isn't going to vary much with current. Unlike a filament lamp, where the resistance changes hugely with current and filament temperature.
yes, the current carrying cap was on my mind. its partly clipped direct, then along the floor void and up through the stud to the 45A switch on the landing wall not much to derate the cable. oh, now is that a problem 45A rated switch/50A breaker?
thanks
thanks
No..................
Does the manufacturer quote 9.8kW @ 240V ?
If so, then that is equivalent to 8.99kW @ 230V.
8990 / 230 = 39.1A - these are the figures that should be used in calculations
its a triton shower, 2 sizes, it states 9.8k - 45A & 8.5k - 40A. Its currently being protected by a 40A bs1361 cartridge fuse, again another reason why i pondered the voltage in the calc
Sbc,
Geoffsd,
