Currently reading:
**Show Us Your Installs!!!**
Discuss **Show Us Your Installs!!!** in the Australia area at ElectriciansForums.net
S
Spudnik
Right chaps,
Due to a few unavoidable issues, we have lost the original thread and pics etc.
Sorry about that!!!
So, if you want to re-upload your pics then great, if not, give us something new!
Cheers!!
16amp was used for fire and six for used for heating. Working with a local authority so they keep an eye on spare rcbos making sure they are not swapped for blanks
earth 11 was earth to gas which was getting took out when I wired the new 10 mm to gas that day
i was being a arse really, to many beers and nothing to do ! but notice the cpc for circuit 6 is in terminal 8 !
Whoops me bad apart from that its passable considering some on the ones we come across. Open a board and its like spaghetti junction and the test sticker is from a week ago and u have to try and connect a new circuit to it with great difficulty
whats the deal with the RCBO earth connections in the DB? never seen that before, but dont work on domestic.. i was always told that RCBO earths have to go into the same connection as the CPC for identification, surely the RCBO earths need to be numbered?
fitted a small consumer unit today for audio equipment :)
If this is purely for audio I would hav been very tempted to make it TT
whats the deal with the RCBO earth connections in the DB? never seen that before, but don't work on domestic.. i was always told that RCBO earths have to go into the same connection as the CPC for identification, surely the RCBO earths need to be numbered?
Correct, RCBO functional earth leads should be connected in the same earth terminal as the circuits CPC. That is the case whether it be domestic, commercial, or industrial.
Recently changed a board, I think that the tails outer sheathing should go right up to the main breaker but the 25mm tails were being pigs to bend. I'm open for constructive criticism to improve in future, also the spare ways may be used shortly - the client is having work done so spares have been left in accordance with prospective additons
Before and after, may of got it a bit neater if I had more room and wasn't standing so high up a ladder
Still at least it's labelled (the marks on the fuse boxes were mine working out what was doing what) and has all the cpcs connected, quality way to cure your rcd problems by removing them :sick:
Reply to **Show Us Your Installs!!!** in the Australia area at ElectriciansForums.net
