L
Lordy9099
Hello,
How many cables can you take from the back of a plug socket to take another spur?
Callum Lord
There is one spur at the moment and I need to take another from this socket, so two spurs and one main supply. So overall there will be 3 in each terminal.
OK, I'm guessing you're not a sparky so I'll give you a direct answer - if there's one "feed" you shouldn't have any more cables unless its a radial circuit. I definitely wouldn't be adding 2 spurs to what could already be a spur.
Lordy9099,
ackbarthestar,
