L
Lordy9099
OK, I'm guessing you're not a sparky so I'll give you a direct answer - if there's one "feed" you shouldn't have any more cables unless its a radial circuit. I definitely wouldn't be adding 2 spurs to what could already be a spur.
No I am not a sparky, it is in the garage and it is defently a spur you can see the main cable run in to the socket and the spur running out and into the other socket. So shall I take it off the other socket that is the spur is taken? And it will only be running an outside light that will go to a FSU and then the power to the FSU from the socket as a spur? The light would only be on when needed, not always.
Callum Lord
