S
spex
Afternoon guys, i am just looking for abit of advice...
i am fitting an 8.5kw shower, the installation is a TT system, the consumer unit has a 63a 30ma rcd covering all circuits as the main switch, it has 16mm tails, what i am thinking of doing is splitting the tails using a henley block with 16mm tails to the new 2 way rcd unit that i am going to fit with a 63a 30ma rcd and a 40a circuit breaker, i am wiring in 10mm twin and earth. the original consumer unit is not labelled correctly, when im asked on the installation certificate about comments of installation do i write nothing because i am not using the original consumer unit?
