E
ed-ectrician
Any tips on the best flat wood bits? Bought makita ones - didnt last for even one first fix!!!
Dynamite works a treat for me, Seriously though ive just bought the makita one's hopefully mine last longer than one first fix
bosch self driving bit on the end of my milwaukiee fuel drill, hot knife through butter !!!!
I've found that auger bits work 10x better than flat bits. But that could be because the auger bits are new and good quality and my flat bits are old and rubbish.....
Bosch do a good new flat bit. They seem well priced.
The armeg beavers are good but hit a nail and they are toast
Sent from my GT-I9300 using Tapatalk 2
We use these from CK in an angle drill so plenty of torque with low speeds and they fly through.
Got a stubby 32mm armeg for £11 delivered. Will check what all the fuss is about. Thanks lads
+2 on auger bits...
A lot better than flat bits, they went out with shell suits...
Try them, you wont look back...
Sent from my Xperia S using next doors WIFI
Try an auger bit you'll never use flat bits again.
Alougth when first fixing timber frame houses I write off an auger bit to every first fix... If one lasts more than one house its a bonus.
