Why not perform the re-wire and once complete get the DNO out to fit a new isolator then so there is no down time, can't understand why the OP is asking how to isolate the system though............it looks fairly simple to me.
Goggles and a sledge hammer....................
im 42 put plenty left in me.
cutting the seal and pulling the fuse is NOT illegal so lets get that urban myth out of the way right now
metering equipment belongs to metering company same as sevice head belongs to dno, legal action can be taken against anyone believed to be tampering stealing or damaging equipment
how many electricians do you know of that have been taken to court for cutting a seal and pulling the service fuse ?
and by the same token how do you know its in good enough condition to be left in ?
the fact its at least 40 yrs old suggests its come to the end of its usefulness.
eh?.....
i think you`l find the point was....that it doesn`t have to perform its original function (ADS)....but may still be good for manual isolation.....so you test it....and if it manually makes n breaks ok....then why discard it?...lol....
Do you wire boilers into lighting circuits? Its not its original function, but its safe and works!!
To me, leaving the VOELCB is like demolishing an old house and building a new one, but leaving and re-using the crappy old wooden porch stuck to the front, instead of renewing everything at once.
So by your own admission, you’re a rip off merchant.
You don’t understand the technology, it’s old, got to sell the customer an isolator they don’t need.
You take a modern isolator and a VOELCB and see the difference in the main contacts. The VOELCB is fault rated, it has arc chutes designed for breaking an arc.
2[SUP]nd[/SUP] thoughts don’t you’ll never be able to put it back together!
ouch tony!!......lol...
just because they deem not to prosecute (even with theft of electricity it is rare) does not mean they cant or wouldnt. Just because they choose not to does not make it right.
earlier posts have mentioned moving the tails live, this is something i would never do and have always removed the fuse and always will, and would gladly state my case in court if ever needed, that is my choice, but to ignorantly state it is allowed is a different matter.
cutting the seal and pulling the fuse is NOT illegal so lets get that urban myth out of the way right now - prosecutions are only brought about if electricity is extracted without being paid for , end of.
so stop mincing about and ditch the prehistoric veolcb for a 2 pole switch and take it from there.
Think Biff you might need to invest in a copy of the ESQCR-2002 and have a read of
Section K 24(2)
This paragraph requires cut-out fuses to be locked or sealed in position to prevent them being removed or the supply being interfered with by unauthorised persons.
To be honest I don't know if you personally are authorised by each and every DNO in the country to pull a fuse, and if you are then great, but you would be one of not very many
And just in case you don't want to adhere to that statutory document the BS 7671-2008 tells us in regulation 537.1.3 that only DNO authorized persons are allowed to pull the fuse
So this maybe one electrical myth that just happens to be true.
I'm not ripping anyone off, just wanting to do a complete job. And I do understand the technology. The VOELCB has arc chutes, and the isolator doesn't, as it is not designed to break loads. Not that that's relevant here anyway, as whichever device is being an isolator it won't be required to break loads as the RCD will do that.
There's no need to start getting personal because we have a difference of opinion. Isn't the purpose of a forum to discuss things?
And no I probably couldn't put it back together as I don't have a pre-war sized screwdriver!
and if someone decides to isolate using the device without disconnecting loads first....
unskilled/uninstructed person/s not under supervision n all that lot.....
Well you could say that about any no-load isolator. Maybe all isolators should be made to break loads. Not a bad idea really...
Anyway, on to the pulling-the-fuse conundrum: I've never understood why they need to seal up the main fuse. Its obvious why the meter has to be tamper-proof, but what's the problem with disconnecting it from the supply?
Off to bed now, I've got a busy day of ripping-off tomorrow. ;)
to stop people (or others) pinchin power......
for example if someone`s got a `grow` on....lol...
