I don't have any official calibration certs for any of the instruments, only our in-house annual test logs. We are registered to self certify our own equipment. Most of these testers are so old I'm not even sure that would have even come with calibration certs.
Here's another one
This is the only tester I own that I've never used. It's an old hi-pot tester (this one is called a Vibrotester) which basically a mega tester. It also has a DC voltmeter and ammeter. The internal caps of this unit looked very deteriorated and I was always torn between replacing them and just leaving it in original condition. Being a big fan of eyebrows, I've never mustered the courage to stick 300 Amps through the ammeter either :)
Some decent kit there, and you actually have to know what to do with it and what the readings mean which helps develop understanding IMHO.
This still gets a work out on occaisions, sometimes when the latest 'plug and play' gizmo has decided it doesn't want to.
That's a nice looking tester, looks like the UK manufactured version to the american one I have pictured above. Mine's unfortunately not in pristine condition internally. The components haven't aged too well and look suspect.
It was made in the '60s by a British company G&E Bradley Ltd, they became Lucas Defence Systems in the '70s. They also held calibration and repair contracts for post war American military stuff, so it's likely that there is some tie up between it and yours.
It's worth keeping an eye out on eBay for Bradley stuff as it comes up from time to time for humble money. You may well be able to harvest what you need from the internals of an incomplete set.
Here's another one
Not sure you would call this bit of test gear a Hi Pot tester Marvo. Hi Pot's normally deliver a high potential voltage (normally in the range of 5KV up to anything approaching 60KV to 120KV) and read any leakage in milli amps, rather than in Mohms. The closest commonly used test kit being a ''Flash tester'', which works roughly on the same principle, but i wouldn't call even these a Hi Pot tester...
Do you have any manufacturers data/instructions on this bit of kit??
This device produces a test voltage of 1.5 - 2 kV according to info I've seen about it so I might be wrong calling it a hi-pot tester. Unfortunately I don't have any documentation on it whatsoever. There was a manual for sale on EBay but they wanted 25 or 30 USD for it which I thought was extortionate plus we don't have paypal where I am.
*edit*
If I have some time this week I'll try a battery in the tester and see if there's any action. Not sure what the battery voltage would be but I'm guessing either 9 or 12v. Looking at the component condition inside it I'm skeptical whether it will work but I'll let you know.
This weekend I saw an advert on our local Gumtree saying megger tester for sale at ZAR200.00. I couldn't resist and when I went to view the tester it turns out it was actually 2 testers for sale.
These things sent a shiver down my spine and I'm sure there's a few members here who will know a lot more about these than I do.
What I can say is they're manufactured in Acton, London by Evershed and Vignoles who later eventually became the company 'Megger' that is today. They're a beautifully made piece of kit somewhere around 1920ish I think, oak boxes, all metal parts are brass and hand made. Both work perfectly. The one on the left is a standard series I Megger tester with a dual scale >50Mohms on the low scale and >10000Mohms on the high scale. The one on the right is what they called a 'High Range Constant Pressure Tester' with a scale > 1000Mohms.
