Darkwood
I will try be more clear, the outer sheath is designed for environmental protection of the inner insulation it can be ordered in many combinations and tolerences for the environment it is going to be subject to, i use specialised cables like Lapp and Igus in Energy Chain systems, any sheath has a tolerence to mechanical damage so it would be wrong of me to say it dosent provide any but regarding T&E pvc cables it is soft easily damaged thus provides minimal mechanical protection. In a sense it can be disregarded it is that low unless you consider attacking it with a feather duster which im sure it will resist, re' the regs any cables regarded as having mechanical protection would be your Micc's and swa's etc as im sure you know but even on these if they have an outer sheath it is there for environmental protection of the inner cable constructs.
This was also made clear when i did the stupid PAT test course where many made the error of thinking the outer sheath is there for mechanical protection, consider oil resistant flexes which again are made up of inner insulation and outer sheath... you can easily split the sheath open with finger pressure applied the correct way but used correctly they will not degrade while running your oil pump on a machine.
Yes you raise a good point regarding the meter box but each situation as it comes and in this case you will only be going through one building construct straight into the meter box, and lastly regarding the numerous older properties with no cavity, they are often loose rubble filled in the middle so require the protection to from the crushing weight that can occur and also alot of old properties were subject to polysterene insulation in the walls which eats pvc so another reason to protect the cables as you dont always realise its there.
