Yes........ but the relay you referred to has not got that feature.... Google is indeed my friend LOL
From the "Product Information" tab for RS 511-1026:
16A 2NO step DIN relay, 230Vac
16A Step Relays - 20 Series
The 20 Series are available as DPST-NO or SPST-NO + SPST-NC step relays. On
each successive energisation of the relay coil the contacts will change state
thus providing a step or "flip flop" sequence of operation. An override test
button allows manual advancement of the step sequence and individual mechanical
flags provide visual indication of contact status.,Typical applications would
include the control of lighting where push on push off or sequential operation
is required, automatic opening and closing of doors, gates, etc. Use in portable
or battery powered equipment requiring contact status to be maintained without
continuous supply to the coil and functions where manual override operation is
desirable.
17.5mm wide (EN 50022) 35mm Din rail mount
housing
Manual test button and mechanical indicators
Minimum impulse
duration: 0.1sec
Maximum impulse duration: 1 hour
Insulation between coil
and contacts (1.2/50μ); 4kV
Nominal lamp rating: incandescent (230Vac);
2000W
Compensated fluorescent (230Vac); 750W
Temperature range: -40 to
+40°C
Protection category: IP20
Latching push button Schnieder do them, could then use standard relay or contactor will try and get you a part number
desirable.
housing
Minimum impulse
duration: 0.1sec
2000W
+40°C
Yep.. that will do....
Think this is the one in white they also do illuminated ones in various colours RS 380 5224
Hi, just had a look at the specification, looks right to me
The 20 Series are available as DPST-NO or SPST-NO + SPST-NC step relays. On each successive energisation of the relay coil the contacts will change state thus providing a step or "flip flop" sequence of operation.
What you need is an 'Impulse relay' Din rail mounted. Controlled by a momentary push to make switch. Push once relay closes, push again and relay opens. Merlin Gerin do a good range.
Good luck
Jerry
Hi, thanks to all for your responses it seems that this effectively called 'impulse relay' or 'step relay' (these can have other functions) or 'latching relay' (sometimes is just called this way). It seems that the name varies from a company to another but I have found a bunch of products now I know what I'm looking for. Again thanks to all because I was looking for this for months withous success. Thanks, thanks!
