G
Gingergreyhound
Hi all can anyone help I'm working on a 3 bed bungalow the incoming supply is pme'd in a garage over 30 meters away from the property and the ccu is in the house which is being fed by a 4 mm micc/pyro from the garage. What is the max load for this type cable thanks mike
what do you think it is, im sure we can tell you if it is correct or not( with some more info from you)
Probably around 40-45 amps at a wild stab in the dark guess, maybe less but you will need to look in the Bible to be sure, too tired and worn out to look for you haha
Thanks all for your words wisdom I will get the regs out and return with answers
If heavy duty another 2 to 3 amps could be added, I will check the 44 amps myself later to see if he's right lol
