That's on a eicr. You haven't to comply with 17th if you change the fuse board
Hold on... when carrying out alterations and additions you have to assess that the earthing and bonding is present and adequate for ongoing use. If the bond was installed to a previous edition and you have identified no safety issues how can you justify that it is mo longer safe. When you change the board you note on your certificate that the bonding has been verified for continuity and condition and that it is to previous regulations. Job done. Different kettle of fish if there us NO bonding or deterioration, then yes bonding to 17th would be needed.
Robert you are digging that hole again we warned you about a week or so ago, get a grip man.
I have recently gone self employed and already had my first awkard customer.
I have quoted for a fuse board change and on my visit noticed that the gas is not bonded. The customer is happy for me to go ahead and change the fuse board but does not want to pay extra to have the gas bonded.
I am just wondering what my options are? Obviously I want to do the job correctly and bring all earthing up to standard and build a reputation as someone that goes by the book but at the same cant to afford to turn away work.
Live and learn, so if the customer won't pay you have a dilema.
Make sure you next CU quote shows the bonding as an "extra" if required, and explain what that means. PLUS you should also have the same for the tails
My CU template includes a statement that says if faults are found during the change additional charges may be applied. Never had this questioned as yet.
Tell em to go do one one mate, I have had that countless times, last time when some one told me they didn't want to pay extra for water and gas bond when asking for a board change I just said no worrys and walked out, the thing is there's always someone out there that will do it for nothing
Sorry if I have the wrong end of the stick that's how I understood it.
That was kind of a question aswell as a response.
Allways do written quotation with terms & conditions like this... You will make mistakes but gain experience. To get a good repo sometimes you dont make no money from some jobs to make the customer happy..
i thin k what robert meant was that on a board change, you can leave undersized bonding if it complied to previous regs. and shows no signs of deterioration. as long as younote it on your cert.
Possibly but he didn't articulate it very well!
neither is the female species. they pretend they are, but all they do is hop from 1 task to another and neither gets done. it just looks as if they are capable.
- - - Updated - - -
- - - Updated - - -
so true
Paul117,
Robert Turnbull,
