What cable do you use when you come out of the outlet plate and into the oven if you have used a 6mm twin and earth for the feed? Would it be a 6mm flex?
Personally I use 2.5, 4, or 6mm depending on the demand of the cooker/hob fitted. If you install a cable buried in a wall then it should have some degree of over capacity for future upgrades. When you're fitting a length of cable which is exposed and easily changed if required size it according to the current (in both senses) requirement. I find that 2.5mm 3093Y is frequently adequate when the reference method is taken into account.
