L
linfield-sparky
Could some bright spark talk me through wiring a cylinder stat and a motorised valve. There is a 2 channel time clock (not wired) at the CU and the cylinder,stat and m/valve is at a cupboard in the bedroom. GO!
Install cables between all components. Terminate cables to components. Test cables that you have terminated. Turn on power. GO!
Theres a lot of abuse floating about on this forum lately, i thought sintra's answer about summed it up perfect and i=p/u
What the hell is wrong with some people, it doesn't take long to find the info if you look in the right places, Honeywell do an app that I have found useful on more than one occasion. You shouldn't pick a problem with sintra, he does know what he's talking about, if you don't like what anyone has to say, then don't type it out, makes you look unprofessional
