Jay Sparks
Mentor
So, most of us were not born a sparky, with the exception of a few lads on here, tel, Tony, malcolm, E54 etc So I just wanted to know if you ever did anything, with electrics, that would make your teeth curl, before you became a sparky?
Now Im gonna stick my neck out and start it off.
When I was about 11, I had been given a video recorder (Betamax). It was nearly new but didnt have a plug!!!
I had a little portable tv in my bedroom that the video recorder was going to work on.
"How can I make the VR work"??? I thought to myself.
I stripped the insulation from the lead of the video recorder, with my teeth and placed them over the socket holes. I then used the tv's plug to push the stripped cable into the socket, thus giving power to both tv & video. Arrrrgggghhh!!!!!!!
At about 9, I had a charger for something, I think it was for my Atari. Anyway, one day it didnt work so I pulled the sealed plug apart. I couldnt see what may have caused it to stop working (not that I knew what I was looking for), so I thought I would plug it in and see if I could see owt sparking. Well, as you can probably imagine, with the back of the plug missing and my hand pushing it into a switched on socket, I ended up at the other side of the room. Arrrrggggghhh!!!!
So, have any of you done owt stupid like this, before you were aware of the actual dangers of electricity?
Jay
at 9 or 10 i found one of my dads screwdrivers laying around ... took it into my bedroom and at about a 10year olds heigh (4ft ish) decided to gouge a massive hole in my bedroom wall, i went and got my mum and showed her the hole saying 'look! Im an electrician like dad' She wasn't amused, and i got absolutley rollocked.
Looking back now, maybe i was trying to chop a box out? Ha, who knows.
Hmm.
ok.
not shared this with many but
similar age, Butlins, looking around the chalet. Whole school there occupying an entire block. Was particularly drawn to the shaver point. Noted I had a small dagger shaped keyring knife so wondered what might occur if the said item bridged the intriguing looking pins of the shaver point...WOW that was a nice firework display.
Whole block went down. Never let on it was me.
I suppose I must have been about 13 or 14 at the time, I was changing the light fitting in my bedroom, turned the breaker off, and someone (I suspect my brother) saw it and turned it back on. Realising there wasn't much point trying to work with the power off I got a pair of marigolds out from under the sink and did it live. I managed to accidentally create a short circuit which tripped the MCB, made a black mark on the palm of one of the gloves and gave me a bit of a fright, but I didn't get a shock from it. I decided I'd do it with the power off when my brother was out.
A couple of years later I did the sound for school stage shows. The wiring in the school was old, wired in MI, and we used to get problems with ground loops (possibly from running about 10 extension leads from one socket), so 'standard practice' was to whip the cpc out of the mixing desk and leave it dangling out of the plug.
Of course now I realise the potential danger of doing that, not to mention it's illegal.
Made a socket tester once as a kid,plugged it in and the first socket it showed earth fault,plugged it in another and it exploded in my hand,funnily enough the bang didn't bother me too much,I also did the school audi systems and was showing a new lad the ropes as I was coming up to leaving,told him to set up,do sound checks etc then LOCK door when he left,he kept leaving door unlocked and I nipped in and swapped Beethoven for the sex pistols,the heads face was a picture as the school trooped into assembly to the dulcid tones of Sid Vicious belting out Frigging in the rigging,And finally, the everyday electrics were the responsibility of the caretaker back then and there was about 6 bulkheads needed replacing in the car park,he hated electric and asked me what I wanted to do them,as i was always doing bits in the labs (h&s? dont think it existed back then) so I went in on saturday morning and did them in return for a load of cleaning products,mum never bought anything for about 6 months,me and a mate had a lovely sideline building alarms and flogging them to market traders for their trailers.
I found my dads hand drill in the garage, think I was 9ish at the time.
When my dad next returned to the garage he found loads of nicely drilled holes in his worktop. He wasn't impressed!!
When I was about 9 or 10 my parents put an old washing machine out to be picked up for scrap. I decided to remove the motor and see if I could get it to work in my bedroom. Needless to say, plugged into a mains socket it wasn't happy. No RCD's back then, just a whole lot of luck...
No i don't think it did. I used to do the stage lighting as well, which involved going up a 3 stage aluminium tower and hanging the lights on 48mm tube 'fixed' through the ceiling to the rafters of the main hall.
It was a great tower, constructed such that one kid could build it on his own by resting a side piece against the stage, then hanging the side pieces on the corners of the already constructed ones. When focussing you could take the top side off and sit on the top ladder (at 45 degrees) with no kind of handrail or protection and get some kid to push the tower around, or alternatively you could take the brakes off and pull the tower around using the bars fixed to the ceiling. We never bothered with outriggers - no point.
When the tower was in use elsewhere, or if we couldn't be bothered to build the tower or move all the chairs out of the way the caretaker had a long 2 section ladder, which we could 'walk' up so it was vertical, push the top section up as far as it would go, get a kid to stand behind it holding it upright, go up 2 rungs and push the top section all the way up to the ceiling so it could rest on one of the ceiling bars, which hung down no more than a foot off the ceiling. Never mind all this '3 points on the ladder at all times' - we had to get the lights up there somehow. I seem to remember doing a lighting rig on my own using the ladder once.
I wouldn't do it now. I doubt the kids are allowed to do it now (not that we were supposed to use the ladder anyway). They're probably not even allowed to use the tower now.
Aye Adam we had a geat big step ladder too about 20 foot tall with no guard rail on top oh happy days
The rule of high stepladders was simple...always hold onto something vaguely sturdy with one hand when working from the top. That way, when it dropped out from under you, you could hang on while waiting for someone passing to put it back up :)
slipped on my mums bungalow roof once and shouted to the guy over the road for help," hang on i'll get a ladder" he shouted. Hang on! the claw marks in the moss were visible for ages lol.
Not mine but still relevant. A school mate decided he was going to learn to play guitar and bought himself a cheap Les Paul copy, he thought that the way to get it loud was to put a plug top on the end of a jack lead and plug it into a socket. Luckily he rang me first to find out if he was right, good job I liked the lad
Tried to fix a train set passed down from my father. Now when I think about it the transformer wasn't exactly safe. Plug top from socket to transformer, 2 core wrapped around 2 uninsulated brass terminals that I thought I would tighten whilst energised. :oops:
The other rule is to point your toes outwards so they hook behind the stiles, then as well as the ladder holding you up you can hold the ladder up. Also if the ladder drops out you're in with a sporting chance of being able to hook it back up.
Not that I'd do that nowadays of course.
During my apprentiship, there was a set of lights needed lamps changing. I climbed the ladder with 2blokes holding them upright. Mind I was a lot thinner then. Wouldn't dream of doing it now, I don't think I'd bounce the same.
