So, most of us were not born a sparky, with the exception of a few lads on here, tel, Tony, malcolm, E54 etc So I just wanted to know if you ever did anything, with electrics, that would make your teeth curl, before you became a sparky?
Now Im gonna stick my neck out and start it off.
When I was about 11, I had been given a video recorder (Betamax). It was nearly new but didnt have a plug!!!
I had a little portable tv in my bedroom that the video recorder was going to work on.
"How can I make the VR work"??? I thought to myself.
I stripped the insulation from the lead of the video recorder, with my teeth and placed them over the socket holes. I then used the tv's plug to push the stripped cable into the socket, thus giving power to both tv & video. Arrrrgggghhh!!!!!!!
At about 9, I had a charger for something, I think it was for my Atari. Anyway, one day it didnt work so I pulled the sealed plug apart. I couldnt see what may have caused it to stop working (not that I knew what I was looking for), so I thought I would plug it in and see if I could see owt sparking. Well, as you can probably imagine, with the back of the plug missing and my hand pushing it into a switched on socket, I ended up at the other side of the room. Arrrrggggghhh!!!!
So, have any of you done owt stupid like this, before you were aware of the actual dangers of electricity?
Jay
Jay
