M
mossview
i want to run a new 6mm cable from my kitchen to c.u in garage thinkin of going thru wall in kitchen along outside wall in trunking and back thru wall to garage would meen alot of mess if ran internal can anyone see a problem doing this method
Right lets get back to basics. What size OCPD are you using, have you calculated diversity for the oven, is your bonding and earthing acceptable for BS7671.
R A F springs to mind,there has to be a better way white trunking run along wall outside,no thanks sooner have a gas cooker.
bonding and earthing on the cooker 6mm will be large enougth for diversity whats a ocpd
Circuit Protective Device. AKA the fuse or breaker.
Then why fit this cooker if you are already planning on upgrading?
You need a qualified registered sparks for this job mate. What you have said already displays your lack of competence for this job. Ask away for more advice though. Your choice :wink_smile:
